Wtc
Here's a 1/400th scale Revell Typhoon on eBay:
http://cgi.ebay.com/Revell-1%2f400-S...QQcmdZViewItemLast edited by toppack; 03-14-2009, 11:35 AM.Leave a comment:
ive enver heard of a revell typhoon. Didnt come up in my internet search either.Leave a comment:
The gears you see were cut from a brass rod that arrived pre-cut with the 48-pitch, 11 tooth gear pattern I use as pinions in my gear reduction units. I simply bore disks cut from that rod to the required size and attach them to the 1/8" shafts you saw in the pictures.
You get those SD's from Caswell Inc. Soon ... very soon. As you can see, it's nothing to convert from single to duel-shaft arrangements in no time.
David,Leave a comment:
Wow Merriman that's really awesome! Where can i get those sub-drivers taht small? and those gears? *really excited now and not dissapointed* hahaLeave a comment:
ps is that the 1/350 dragoon model cause i see mike doesnt carry it.Leave a comment:
david,
OMG If you can get your butt busy I might get a typhoon running for the regatta. Get your butt in gear. I wasnt even concerned till you showed that typhoon and now I am angry that you arent finished!!! Get your but in the garage and get that stupid thing read for production!! I want one now. I will call Mike if I have to.Leave a comment:
Plenty of stuff.
... Right now I'm working a process to separate U235 from U238 with a kitchen strainer for an Iranian customer. Wonder what he needs that for? Film at 11.
Any more secrets up your sleeve David :p? That is absolutely amazing!
I see that it now has a snort system up front. My dream of seeing a static diving Revell U99 someday isn't too far off.Leave a comment:
As you can see, I've designed the basic single-shaft 1.25 SD so that with the simple addition of an idler gear equipped with a shaft, I can produce two counter-rotating shafts from the basic 1.25 SD motor bulkhead.
Powering a two-screwed submarine? ... No sweat! Been there, done that, got the T-Shirt!
So, so many little plastic submarine kits out there to convert to r/c ... so, so little time!
Just get the 1.25" SD. Since the SD has a single motor and Type XXI has 2 propellers located on the stern planes , you can either make then operable ( more complicated) by using gears to counter-rotate them or just simply do what this guy did with a Trumpeter 1/144 scale Romeo class submarine...what is the Merriman SD? yeah i'm a newb, i went and bought a plastic revell model to convert 1:144 and it's too small also the propellers are on the fins? so there's no way to drive it. it's a u2540 xxi. well anyways. I would like to scratch build my wtc, i just don't exactly know about the electronics part and how to calibrate servos... if you have too
The Merriman SD - means Subdriver branded WTC built / designed by David Merriman III.what is the Merriman SD? yeah i'm a newb, i went and bought a plastic revell model to convert 1:144 and it's too small also the propellers are on the fins? so there's no way to drive it. it's a u2540 xxi. well anyways. I would like to scratch build my wtc, i just don't exactly know about the electronics part and how to calibrate servos... if you have too
For more information on how small these WTC are and the plastic models that they can go into visit the caswell website of which this forum is part of:
