fhouldson
  • fhouldson
    • Feb 2013
    • 45
    fhouldson
    Would like to know how to get a hd-1550a Mico servo for 2.5 wtc. Mine quite working and could not find one on sub driver. It works the ballest vent.
  • Anuci
    Banned
    • 165
      Try This: http://www.sub-driver.com/electronics/servos.html
        You want the 'micro' servo
        • fhouldson
          • Feb 2013
          • 45
          snort pump
          the controller on the snort pump quit working. Is there a way to wire it in with out the controller.
            If the little green light on the face of the MPC still gloes green when 'on' then the motor is likely shot. If the green light does not illuminate then the MPC is shot. Don't want you to get the wrong thing to make the fix.
            Only way to control the LPB motor from the receiver is through an electronic switch such as the MPC, or using a servo to operate a micro-switch (mounting the micro-switch so that the ballast sub-system servo closes it in the 'blow' postion).
