air vacuum pump for my WTC
  • wroozee
    • Dec 2009
    • 1
    I am building the revel 1/72 VIIC u-boat. I see caswell has an air vacuum pump that is 6 volts and also has both an inlet and outlet tube connection.
    My question is, does this pump need a clippard type valve to release the pressure in the bladder, or does this pump have this feature built in?
    • 13988
    No, no pump installed dump-valve provided. So, if you're going to do the RCABS thing, you'll either need to install a solenoid or mechanical (servo driven) dump-valve.
    Forget RCABS for the little type-7 -- unless you're a genius, like me, you won't be able to get enough bag in there to displace the water needed to yank that hull up to designed waterline.
    Buy our SubDriver and get it right the first time.
    I bring you up right; I buy you books; I send you to school, and what do you do?! .... you eat the teacher! What's wrong with you people?!
      • 2642
      Hungry cannibals?
        • 13988
        Hungry cannibals?
        Man, Andy! ... I don't know sometimes.
        It's like teaching donkey's differential calculus.
        It shouldn't be this hard.
