Weird glitches underway - troubleshooting suggestions
  • Slats
    • 1776
    #46
    Originally posted by Rogue Sub
    I will say that I have used the sub esc 10 with great success. Just make sure you read the instructions thouroughly when setting them up in tandom.
    Do you mean tandom as in two ESCs for two motors?
    If so I only have one motor so only need a single.
    And if its been successful, why not fit one in the Kilo and Type 7 you have?
    Best
    J
    sigpic
    • Nuke Power
      Banned
      • 277
      #47
      because there isnt enough room
        There is now!
        Sells at $29.00
        • Slats
          • 1776
          #49
          Originally posted by kazzer
          There is now!
          Sells at $29.00
          What is it?
          sigpic
          • Nuke Power
            Banned
            • 277
            #50
            sure mike but can the bec take the punishment and is that designed by kevin?
            • Slats
              • 1776
              #51
              I am now going the separate BEC route only regardless of the ESC.
              There tiny enough devices. The ones I ordered claim to be not noisy electrically,have filter suppression BUT do require the unit to be at least 5 cm / 2" away from the RX.
              J
              sigpic
              • Nuke Power
                Banned
                • 277
                #52
                which one you go with
