Guys,
I'll run this buy the wider forum group - as I am wondering if anyone has had the same glitches underway and what I could be doing wrong.
The boat / WTC (SD) has been working fine - both on the bench and in the water. On Saturday after about 20 minutes or so - I discovered I had full control over all functions except for the foward propulsion. I had full proportional stern thrust - but none ahead. I pulled the boat out and decided to reset the ESC - thinking its lost its neutral spot. This seemed to fix the boat but on sunday the problem returned in an intermission sort of way. I have never had this problem before, the rest of the boat, rudders / planes / ballast control / LPB (snort) works fine. Battery condition was perfect - showing good charge still left in battery.
Any suggestions what i should be trouble shooting / checking next?
John
John
