75mhz radio and reciever?
    I found a VEX robotics 6 channel 75mhz TX and RX. part number 276 2153. 4ch analog 2 digi. and want to know if the Sombra labs rx is compatable with the VEX transmitter. VEX states the possibility of having 2 transmitters utilising the same robot (submarine?) with 2 seperate controlors for multifunction robots. So for another buck fifty, 12 channels and I can run the boat's rudder/planes throttle and ballast on one transmitter. The other augmented tx runs the torpedos, raise and lower perriscope and or schnorkle and other unimmaginable goodies. I dont know if its a good idea or not.Click image for larger version
    • 13984
    I found a VEX robotics 6 channel 75mhz TX and RX. part number 276 2153. 4ch analog 2 digi. and want to know if the Sombra labs rx is compatable with the VEX transmitter. VEX states the possibility of having 2 transmitters utilising the same robot (submarine?) with 2 seperate controlors for multifunction robots. So for another buck fifty, 12 channels and I can run the boat's rudder/planes throttle and ballast on one transmitter. The other augmented tx runs the torpedos, raise and lower perriscope and or schnorkle and other unimmaginable goodies. I dont know if its a good idea or not.[ATTACH=CONFIG]31385[/ATTACH]
    Bad idea.
    Crawl, walk, jog, run, then ... and only then ... sprint. Torpedoes and that crap is SPRINTING!
    You have not craweled yet.
      Bad idea.
      You forget? I came out the woumb flying and hit the deck running, dropped out of 6th grade to work on my masters degree. Sprint? thats a crappy fone service that sponsors NASCAR races and has good lookin promo chicks, that always are smiling. Even when they get a gallon of Mountan Dew poured on their heads. Besides, Dave,I aint got a whole lot of time left on the planet,so damn the torpedoes, ram the throttles to the wall. I want to launch ballistics from a Sinpo, by the 4th of hoolio. Hmmm..sounds like the words of a new country song.
        • 13984
        Go get 'em, Tiger!
