Push plate for bow / sail planes - how do you do it?
    any chance you could point us in the right direction and give us some schooling on assembling a a push plate and linkage for bow or sail mounted dive planes going from the rear end cap of the SD.
    I for one need to overhaul my bow planes linkage on HMS Trenchant. The Flex cable I am using is not going back to centre well (your not surprised I'm sure). I recall somewhere you did an install of some bow planes and stated you used a "push plate" to do this.
    John
    • 14014
    John
    In the 'old days' before use of magnetic connectors you would provide tension on the bow plane pushrod with a spring or rubber band. The bow plane pushrod would push against the WTC/SubDriver pushrod pusher plate.
    Wa-la!
      Thanks - I get it.
      • ADDINGTON
        • 80
        Another option with apologies for anonomous credit:
        somebody sent me the attached shot of his WTC bow plane "pushrod". I copied it for my 1/96 Seawolf. The control rod from my bow planes, constructed of 1/16" brass on both ends for the Kli-Cons and aluminum tube inbetween, runs the entire length in the upper hull to the aft WTC "pushrod." The magnets orient the planes.
        -Kerry
        PS,
        This site is killer.
          • 14014
          -Kerry
          PS,
          Welcome aboard Kerry.
          For those of you looking over our shoulder:
          Kerry Addington is the genius behind those incredible annual SubRegatta DVD's. If you have not seen his work (the videos) you're missing out on not only excellent r/c submarine eye candy, but some of the best above and underwater photography in the field today. His DVD's are both entertaining and informative -- and, yes, I'm present in these videos talking it up during both regatta pool activities and while lecturing during the symposium portion of the event.
          Kerry's one of us, guys. AND he's a professional videoographer.
          Kerry: tell these bum's how to order your DVD's. And if you have a sample file of your video post the site here and let them enjoy the pretty pictures.
          • toppack
            • Nov 2008
            • 1124
            The control rod from my bow planes, constructed of 1/16" brass on both ends for the Kli-Cons and aluminum tube in between, runs the entire length in the upper hull to the aft WTC "pushrod." The magnets orient the planes.
            -Kerry
            I assume there are magnets glued into the ends of the aluminum tubing also, correct?
            Rick L.
              • 14014
              Yup.
              • ADDINGTON
                • 80
                Very kind words David.
                Probably no suprise to many of you that when it comes to this hobby and David D. Merriman III in particular, I have received a hundred times what I have given.
                Great to see this website running the reactor at 110.
                As such, rather than waste space here, please send me a PM if you need any info on the DVD's.
                -Kerry
                • Nuke Power
                  Banned
                  • 277
                  -Kerry
                  PS,
                  Hey what the I wear PINK underwear!I wear PINK underwear!I wear PINK underwear!I wear PINK underwear! Kerry thats my boat. Dont you know I have that copyrighted!!!!
                  Not really though. Anyway those rods arent aluminum. Unlike David I use NiCu rod for everything. It doesn't corrode and is much stronger then aluminum or brass.
                  • ADDINGTON
                    • 80
                    sorry, I always want to give credit.
                    The aluminum tube I was referred to was regarding the linkage rod in the upper hull of my boat.
                    Thanks again for the pushrod idea!
                    • Nuke Power
                      Banned
                      • 277
                      well as long as the credit train is running through. The idea is actually merimans. I just built it as the cabal report stated :) Wish it was my idea but oh well. You can keep stealing from me kerry. Oh heys wheres my darn video :)
