Sub Regatta down under in Octoer 2013
  • alad61
    • Jan 2012
    • 476
    Recently my wife and I went to the sub regatta held down in Gosford which is approximately 1100 Kilometers from home. Normally Sandy hates being in the car for more than a few hours, to which we had discussions of many about but she didn't want me to drive that far on my own. How ever next year when I attend the Canberra one she stated very clearly that I can drive and she'll fly down when I get there.
    The week end was a real treat for me as I had never been to one before and I was able to drive my boats deeper than my scopes just skimming the surface due to the water in most of the local ponds being murky and less than favorable to diving subs deeper than periscope depth. Also I realized I have been spending so much time editing all the videos and picture that I hadn't posted any shots from the event BLUSHER
ID:	102764Click image for larger version
ID:	102765Click image for larger version
ID:	102766Click image for larger version
ID:	102767Click image for larger version
ID:	102768Click image for larger version
ID:	102769Click image for larger version
ID:	102770Click image for larger version
ID:	102771Click image for larger version
ID:	102772Click image for larger version
ID:	102773Click image for larger version
ID:	102774Click image for larger version
ID:	102775Click image for larger version
    More to follow...
    Cheers,
    Alec.
    Reality is but a dream...
    But to dream is a reality
    Originally posted by alad61;30129
    [url
    http://forum.sub-driver.com/attachment.php?attachmentid=23859&d=1383434065[/url]
    Is that a Darnell T?
      • 13991
      Alec,
      Beautiful venue. Was that the big, 24" Teskey FS-1? If so, I did the fittings kit for that beast.
ID:	84253Click image for larger version
ID:	84254Click image for larger version
ID:	84257Click image for larger version
ID:	84259Click image for larger version
ID:	84260Click image for larger version
ID:	84262Click image for larger version
ID:	84263Click image for larger version
ID:	84264Click image for larger version
      Your SKIPJACK looks great. How did it behave?
      • alad61
        • Jan 2012
        • 476
        Yes it was the Teskey hull and it was a beauty to behold that for sure.
        My Skipjack was a dream to run and I took your advice and dialed back the throttle to 40 on the epa which was like a reinvention of its handling. In fact it was the first time I actually drained the battery to it's limits and the sas preformed as expected. The only glitch to the week end was that there was some issues with radio interference which we put down to the chlorine levels being a bit high. The only issue that caused in the Skipjack was that if I didn't close the ballast vent the ballast servo wouldn't operate when the signal came back so when the sas kicked in the air blew straight out of the ballast vent... Lesson for me was to close the vent after flooding the tank, something I do get a bit lazy with because at home in the local ponds I won't go below periscope depth.
        Cheers,
        Alec.
        • alad61
          • Jan 2012
          • 476
          I'm not sure. All I can tell you is that it was around or over 6 feet long and that the owner, Pat, has rigged it to fire torpedoes. here it is near a 1/72 sub which I think is a Seawolf
          Cheers,
          Alec.
          • alad61
            • Jan 2012
            • 476
            And some more...
ID:	84267Click image for larger version
ID:	84268Click image for larger version
ID:	84269Click image for larger version
ID:	84270Click image for larger version
ID:	84271Click image for larger version
ID:	84272Click image for larger version
ID:	84273Click image for larger version
            Cheers,
            Alec.
              • 2642
              I don't think so. I believe that is a 1/32nd scale T-class.
              • Peter W
                • May 2011
                • 511
                Pat Drake I am sure scratch built that using the lost foam technique, I am almost certain I have the article.................somewhere. HMS Thrasher I believe.
                Peter
                  • 13991
                  Pat ... balck-powder ... Drake?
                    • 13991
                    • alad61
                      • Jan 2012
                      • 476
                      Yes it is Pats boat. I think his other nick name is Dr depth charge.
                      Cheers,
                      Alec.
                        • 13991
                        Love his pyro work.
                          • 13991
                          Love his pyro work.
                            What prick keeps hitting the SEND button twice eh?
                              • 13991
                              test ..............................
