Subdriver for the Type 23 - some dimension questions
    David and others,
    I have a small submarine project on the drawing board, was wondering about the SAS subdriver used in the Bronco 23 as the sub I'm planning on doing could possible make use of the Subdriver in the Bronco 23.
    So dimensions for Subdiver for the Type 23 please:
    OD
    Length of BT
    Apx volume of BT
    OAL of SD
    John
    • 1651
    John, i've got the long version for my XXIII,
    OD, 62 mm
    lenght of BT, 157 mm
    volume of BT, aprox 400 ml, or 14 ounces
    OAL of SD including bulkheads, 517 mm
    Don't know the overall lenght of the short one, David mentioned that only the battery compartment is smaller, length of mine is, 150 mm.
      OD, 62 mm
      Many thanks Manfred.
      John
        • 13984
        Originally posted by Slats
        David and others,
        OD
        Length of BT
        Apx volume of BT
        OAL of SD
        John
        Outside Diameter -- 2.5"
        Length of Ballast Tank -- 6"
        Volume of Ballast Tank (expressed as weight of fresh water) -- 14 ounces
        Length Overall of Sub-driver -- 20.25"
        BTW, this is the same unit sold as our generic or 'standard' 2.5, single-shaft SD: http://www.sub-driver.com/sub-driver...model-kit.html
          • 1651
          If i remember right, your XXIII SD is shorter as the one you send me, which is a standard 2,5" SD, maybe it's wise to give the lenght of your modified SD to John, so he can decide which one will be suited for his planned project.
            • 13984
            Good idea, Manfred.
            John, here's the dope on the 'torpedo shooting' version of the 2.5", single-shaft SD:
            Length of Ballast Tank -- 4.5"
            Volume of Ballast Tank -- 10 ounces of fresh water
            Length overall of Sub-driver -- 17.25"
              Good idea, Manfred.
              Thanks boys.
