USS Balao 1/32 Fleetboat
  • GBerger
    • Oct 2010
    • 18
ID:	102551Click image for larger version
ID:	102556Click image for larger version
ID:	102557Click image for larger version
ID:	102558Click image for larger version
ID:	102559Click image for larger version
ID:	102560Click image for larger version
ID:	102561Click image for larger version
ID:	102562Click image for larger version
ID:	102563Click image for larger version
ID:	102564Click image for larger version
ID:	102565Click image for larger version
ID:	102566Click image for larger version
ID:	102567Click image for larger version
ID:	102568Click image for larger version
ID:	102569Click image for larger version
ID:	102570Click image for larger version
ID:	102571Click image for larger version
ID:	102572Click image for larger version
ID:	102552Click image for larger version
ID:	102553Click image for larger version
ID:	102554Click image for larger version
ID:	102555These are some of the photos of the boat as it appears today. Based on the old 32nd Parallel kit it was greatly modified and scratch built. It ran for many years and now resides on the shelf. Perhaps I'll re-commission it someday, but for now I have too much on my plate. Next, I'll post some construction pictures.
    The Titanic" The smoker you drink, the player you get"
    Very nice indeed, and welcome aboard sir!
    • GBerger
      • Oct 2010
      • 18
ID:	82156Click image for larger version
ID:	82157Click image for larger version
ID:	82158Click image for larger version
ID:	82159Click image for larger version
ID:	82160Click image for larger version
ID:	82161Click image for larger version
ID:	82162Click image for larger version
ID:	82163Click image for larger version
ID:	82164Click image for larger version
ID:	82165Click image for larger version
ID:	82166Click image for larger version
ID:	82167Click image for larger version
ID:	82168Click image for larger version
ID:	82169Click image for larger version
ID:	82170Click image for larger version
ID:	82171Click image for larger version
ID:	82172Click image for larger version
ID:	82173Click image for larger version
ID:	82174Click image for larger version
ID:	82175Click image for larger version
ID:	82176Click image for larger version
ID:	82177Click image for larger version
ID:	82178Click image for larger version
ID:	82179Click image for larger version
ID:	82180Click image for larger version
ID:	82181Click image for larger version
ID:	82182Click image for larger version
ID:	82183Click image for larger version
ID:	82184Click image for larger version
ID:	82185Click image for larger version
ID:	82186Click image for larger version
ID:	82187Click image for larger version
ID:	82188As can be seen, the hull required major modifications to get it to the correct shape. All the other details such as fittings, 5" gun, props, tower, radar where all scratch made. Understand that this boat predates the major influx of PE parts and the WTC was in its infancy. Much input was rendered by HWSNBN, and without such this project would not have been as successful as it turned out. I couldn't put a WTC of that size anyway. It was powered by two Astro 40 geared motors. CO2 pneumatics to actuate the periscopes, shutter doors, torpedo release mechanisms. It fired all ten tubes. I had four 12v 7a cells for the electrics and an Ansul fire hood CO2 bottle for the pneumatics. The screws are hand made brass and plated copper. I could go on and on. Suffice to say I cut my teeth on this thing and learned one valuable lesson......build smaller.
        • 13982
        What Gene is too kind to mention is that I almost killed him via a CO2 bomb:
        When working out the CO2 gas system (CO2 at room temperature presents a gas pressure of around 800 PSI). I suggested sources for plumbing, gas regulator (the perfect Williams single-stage unit used by NASCAR pit crews), and on-board pressure bottle. What I failed to do was insure that we incorporated a blow-out plug into the neck of the on-board bottle.
        I'll let Gene present the pictures of the shop explosion aftermath. But for the grace of God, Gene was not killed or maimed! To this day I get the shakes just thinking about it.
        • GBerger
          • Oct 2010
          • 18
          Here's the culprit of which HWSNBN speaks. I was indeed very fortunate. I could have lost the boat....I would have healed, but not the boat. It would still be in the depths of Mt. Trashmore, 25' down. That's 800 scale feet. Certainty beyond my diving limits. I had pre-charged the bottle in anticipation of going out to the lake and went out to run an errand. When I returned the work shop was a total mess. The largest piece of the Rubber Maid tool box which held the bottle and all my stuff measure no more then a few inches. The tools were at either end of the place and the bottle in the photo, which was at the bottom of the box under two trays of tools, was deeply imbedded into the ceiling. CO2 systems are cool, but must be treated with the upmost of respect. I didn't and I nearly paid a steep price for it. At the end of the day the system did prove to be complicated and extremely finicky and I would do it much differently today. Lessons learned....I blame HWSNBN....of course. Wouldn't you?
            • 13982
            (hanging head in deep shame). I almost took out the SubCommittee Editor!
            • goshawk823
              • Oct 2010
              • 262
              I remember this like it happened yesterday. That was like, 14 -15 years ago now???
              • GBerger
                • Oct 2010
                • 18
                Yes, that's right. I won't soon forget though.....Forgive me if I don't know your "call sign" ? I'm fairly new to the forum and am trying to catch up to new and old friends. I'll figure it all out eventually....Sam.
                • goshawk823
                  • Oct 2010
                  • 262
                  Sorry about that, Gene! I forget that I'm new to posting here under that moniker.
                  Hey, I had to leave the IPMS show early; how did you make out at the end of the day?
                  -Sam
                  • GBerger
                    • Oct 2010
                    • 18
                    Monitor took 1st in Cat.....Thanks.....G
                    • goshawk823
                      • Oct 2010
                      • 262
                      congrats. great looking model.
                      • Tom Martin
                        • 32
                        Am a newbie and just read this thread and viewed the pics.
                        CRAFTSMANSHIP at its very best! Wow!
                        Tommie
                        nautilusreproductions.com
