Look what I found - a peristaltic pump
    This is a solar fish! It dispenses small amounts of chemical which leaves a thin film on the surface of a swimming pool and prevents evaporation.
    Inside is a pump -- Click image for larger version
    I cut around the plastic welded cover with a Japanese saw and, as I thought, there it was, a tiny peristaltic pump and a 6volt 150 motor drivi
    ng a geared pump.
    Whether it has any use or not, I'll let you guys figure that out, but for about $20, it has to be a cheap way of getting a pump.
  • roedj
    • 564
    Mike,
    Specs - I want specs. Rate flow? Pressure head? Size?
    Dan
      Originally posted by roedj
      Mike,
      Dan
      Don't ask me! I have no idea! Go buy one and figure it out!
        • 13988
        Mike,
        Dan
        Mike's sending me one for evailuation. As it appears -- there's a worm-gear between motor and pump rotor, so the gear ratio is very high --the output CFM's is incredibly small. But, I think we have a useful mast raising/lowering pump and hovering system prime-mover if I slave that pump to a 380 or 500 sized motor of a lower gear ratio.
        Stay tuned, sports fans!
        • roedj
          • 564
          Challenge accepted - where do I buy it?
          Dan
            Dan
            Any swimming pool supplies store
