WFLY 8Ch converting from 72Mhz to 75Mhz??
  • Stefan
    • Aug 2012
    • 10
    Have a WFT08 and the RF module in the back is for 72Mhz. Can I swap it with a module for 75Mhz to get on surface frequency and if yes where would I get one of these WFTRFO1 modules for 75Mhz and the appropriate quartz.
    Thanks, Stefan
    • 13990
    Yes.
    Each module has the radio-frequency tuned circuit within it. If you get the type of module that is crystal controlled (requiring a specific channel crystal installed), then you need the appropriate crystal that is of a channel on that band.
    Or, you can get a module to the band you want that is of the 'synthetic crystal' type, that you can set to any of the channels on that band.
    E-bay is the place to find that stuff. I hear the Hi-Tech modules will work in the WFly transmitter.
    • Stefan
      • Aug 2012
      • 10
      Thanks,
      Found a 75Mhz module on Ebay with channel 72. Still looking for the PLL synthesized ones for 75Mhz to avoid having to swap crystals.
      Good call David!
      Stefan
        • 13990
        Originally posted by Stefan
        Thanks,
        Good call David!
        Stefan
        Thank you, but credit goes to Andy Lawrance and Kevin McLeod for doing the research here, I just passed it on. Good luck with your 75mHz module hunt.
