I see a thread on The Subcommittee forum and for a moment I thought we had an olive branch offered, but then Thor and La Rue decide to chip in on a subject they obviously know nothing about. Neither of them have ever used the plating system, so I'm really puzzled as to why they would post any comment on the concept, other than to dig at me. Ah well! He's on his favorite
The layer of nickel is like an egg-shell on a hard boiled egg. It's very hard, and very thin, so it stops the blades bending, a common fault of white metal props. As for the cost, they haven't thought this through. A D&E prop is included in the D&E Fittings kit and the cost is therefore minimal. The actual cost of the kit would be slightly higher than buying brass props, but you'd be able to plate all sorts of things, especially push-rods, which are prone to corrode. It will also stop push-rods from bending, actually stiffening them up.
As for the appearance, the plated bronze surface looks real and I defy any paint job to match it. It will eventually take on a patina, something paint can't do. Even brass props could be easily bronze plated.
