Yankee notch cutaway
    Literally! Under the Torch of the scraper. Look on the right side. Can you see it? Looks like a launch tube at an upward angle. Ever see the launch tubes down in the notch. Sure, weve seen them from the outside but not from the inside.
ID:	101782Click image for larger version
Name:	Yankee notch revealed.jpg
    • 14012
    Four levels! And I thought these things were big-time torpedo shooters. Wow.
