Revell Oscar-II Rc sub.
  • Jmadigan
    • Jan 2009
    • 6
    Hello, i am new to the RC submarine building and this site seemed like a good place to start. i was wondering, i a was to build a RC sub from the Revell Oscar 2, what parts would i need to complete it as a fully functional model (if there is a way i can use the twin-screws to turn the boat rather than setting up rudders could you also list that.).
    Thanks, your help is appreciated,
    Jeff.
  • toppack
    • Nov 2008
    • 1124
    Using propellers only for steering a RC model is Not good. Difficult to steer and No steering when at slow speeds or when no power to motors (when coasting).
    Also you will need a dual-circuit motors-speed-control, using 2 receiver channels, which is larger and take up more space in a very crowded assembly (not good).
    Oscar on Patrol:
    Rick L.
    • Jmadigan
      • Jan 2009
      • 6
      ok
      ok, so then what would be everything i would need to complete a good boat (other than sub-drier)?
      • toppack
        • Nov 2008
        • 1124
        Do you have the 1/350th scale model?
        Or is there also a larger version?
        If so, I personally would not attempt to build a RC model that small, but some people have done it. Maybe they can help, but I would only be guessing on one that size. Sorry.
        For a first time RC Sub build I would recommend the Revell 1/72 scale Gato kit. It's not too small and not too big. And Caswell has everything you need for it.
        Rick L.
        • Jmadigan
          • Jan 2009
          • 6
          thanks
          ok, i do not believe that there is a larger model. ill try to find a diffrent model then that is larger, thanks for the help.
            Hang fire! Important announcement imminent! Your Revell Oscar is VERY viable!
            • toppack
              • Nov 2008
              • 1124
              Will the 'Cigar-sized' sub-driver that David is working on Fit the Oscar model? :)
              Rick L.
                • 14014
                Film at Eleven!
                Mike?! ....
                • Jmadigan
                  • Jan 2009
                  • 6
                  again
                  I've seen the videos on the home page about the small sub-drivers in the 212a and 214, its amazing how small they are.
                  • Nuke Power
                    Banned
                    • 277
                    Did you guys come up with something even smaller now?
                    • Jmadigan
                      • Jan 2009
                      • 6
                      still...
                      but still, my question has not been answered. what would be all the components needed to build a functional Oscar 2?
                        • 14014
                        I'm working up a package now. Be patient.
                        • toppack
                          • Nov 2008
                          • 1124
                          Yes, I don't think Santa Clause has put his 'Stamp of Approval' on this that one yet. :D LOL :D
                          Rick L.
                          • Nuke Power
                            Banned
                            • 277
                            you are going to need to decide how your going to ballast it first.. then you will need 2-4 servos, 1 transmitter and reciever, 1-2 esc for your motors, a pitch controller, battery, water tight area, push rod seals, drive shaft seal, foam, weight for ballasting, brass rods, controll horns for the controll surfaces.... etc, etc , etc sometimes its best to just buy one your first time around and then most your questions can be answered by that.
                            • toppack
                              • Nov 2008
                              • 1124
                              Yes, if you have Never built any RC boats or ships, it would be best to start with a surface boat and get experience that way. The control and propulsion electronics and hardware are similar but much more is involved in subs, if you want them to dive and surface.
                              Rogue has just started the list of things you you will need to complete it. ;)
                              I built 17 Surface RC ships before I figured I had enough experience to do a Submarine. :D LOL :D
                              Rick L.
