Revell Skipjack
  • vital.spark
    • May 2010
    • 312
    Revell Skipjack
    I've finished my Gato (looks great) and have now started the little revell Skipjack which presents a few new challanges. I've CA'd th hull halves for a better fit, cut off the tail and bonded the bottom bow section to the upper bow. Now the fun begins! I can see no way to work on the new stern section without installing the tiny fragile control linkages first. This means that I haveplace the linkages between the 2 tail sections, CA the two halves together then CA the stern on to the hull, fair with metalcoat, prime and finish paint all with those tiny, thin control linkages in place!!! Is this the way you did it?????
    Regards,
    Myron
