Oring size
    Oring size
    What is the width of the Orings used on the WTC for the Blueback? The O ring is 2 in diameter I think. I’m rebuilding my WTC, and my caliper is missing,
    • 3767
    If it is in the 2mm size that would more than likely be 1/16" (~1.58mm)
      It’s the Merriman WTC for the Blueback. The problem is I’ve got O-rings, but they’re too thick. But I really wanted to know was the thickness. I appreciate it, and I’ll look and see if I can get some of what you just quoted. Hope you are well.
