11.1 Volt electrical system in the Revell Gato
  • vital.spark
    • May 2010
    • 312
    Im doing the assembly on the Revell Gato subdriver and I would like to know if there is anytihing I need to know or do when using the 11.1 volt battery supply? Or, can I just do the same electrical hook up as we did on the 7.4 volt seawolf and type VIIC, just adding the additional channel and servo for the retract opperation?
    I and I'm sure others would like you and or Kevin to post a good quality wiring diagram for both the 6 channel installation and also the 7 channel like the Gato when an ADF, Lipo Guard and LPB are installed.
    Regards,
    Myron
    • 13989
    Myron,
    Yes, just slap the additional servo into an unused receiver port and you're off to the races.
    Here's two version of block-diagrams that show device hook-up in the typical SubDriver:
ID:	65145Click image for larger version
    • vital.spark
      • May 2010
      • 312
      Thanks David,
      A while back I saw some posts on the 11.1v installation but I spent hours and couldn't find it again!
      I think I'll frame your block-diagrams! When I was ready to wire the Type VIIC, I hade to take the seawolf apart to copy it. I do hope others will copy the diagram now that it should be easy to locate in a forum search.
      Regards,
      Myron
