Have you ever found a really great picture and downloaded it to your computer and when you tried to upload it to a forum...........you couldnt find it? Many times thats because Caswells and others systems dont recognize bitmap images. Youll need to change it to a jpeg. How do you do that?
The easiest way is to go to the image and right click on it and select from the drop down list "open with" then select "paint". It will then appear in "paint". In the upper left , click on "file" then "save as" In the box the second line will show the type of image that it is with an icon allowing a drop down box. In that select jpeg and it will save that image again as a jpeg. Then just delete the bitmap image. Then when you go to upload it it will be recognized. KEEP A STEADY BUBBLE..........YOU SWABS!
