One - offs - how to do it?
  • roedj
    • 564
    To All,
    Not sure where to ask this - may belong on Builder's section - move if you want.
    Here's the situation. I want to try my hand at total scratch building a sub. I have experience in building surface craft in wood with the plank on bulkhead/former technique but I realize that that may not be the best way to get what I want. My observation is that all you masters at this scratch building game make a master from foam or wood than make a female mold then pull a male example from it. OK, that's great if you want to produce copies - but I don't. I am only interested in making a one-off single boat.
    I can visualize making a foam master. glassing it then removing the foam - lost foam method. Or, making bulkheads from plans, laying very thin wood planking over it, glassing the outer shell, then removing the bulkheads. Or, ?????
    I have Steve Neill's "Dumb Asses" book. Lots of good ideas there but it's still geared towards making copies. I know I could follow the master - female mold - male copy method but what are my options?
    I would use WEST epoxy (I have experience with it) and carbon tape for water proofing and strength. I'm also not sure if it would end up being a dry or wet hull model.
    Given those druthers, how would you do it? I reiterate, I have NO desire to make copies - only one boat.
    Thanks for your time and invaluable help,
    Dan
    Yes, lost-foam technique.
    Make the foam plug/master/sacrificial pattern from polystyrene -- it won't melt under the epoxy resin saturated GRP layup.
    After glass layup, remove the foam by opening up two holes in the GRP 'skin' and pouring gasoline in the top hole, which turns the foam to mush, the mush is drained out the lower hole hole. Wa-la! A one-off GRP hull.
    Try not to set yourself on fire!
    • roedj
      • 564
      Polystyrene - is that the blue/pink insulation board?
      Good advice on not setting myself on fire - I'll consider it.
      Dan
      • roedj
        • 564
        Dan
        Never mind, I see that the pink/blue insulation is polystyrene. Should've Googled before asking.
        Dan
          Dan
          Yeah, that's the stuff. Get to it.
