2.4GHz radio
  • jean deschamps
    • 2
    2.4GHz radio
    Hi need imformation on radio.Being new on rc sub, would like to know if
    the new 2.4 GHz radio are ok for rc submarine
    thank you Jean Deschamps
  • toppack
    • Nov 2008
    • 1124
    No, Short-wavelength high-frequencies, in the GigaHurtz bands, do Not have much range under water. The old AM 75.Megahurtz band is probably the best to use.
    That's why Whales talk to each other in very low frequencies, much more range. :)
    Rick L.
    • toppack
      • Nov 2008
      • 1124
      I got to wondering about the 'Speed' of Radio signals Under water ???
      I've heard that Sound travels about 3.5 times Faster in Water than it does in Air, so I assume that radio waves would Also.
      If so, then the response times of our Subs controls would be Faster when submerged, correct? :confused:
      Maybe a few milliseconds faster. :D LOL :D
      Rick L.
      • jean deschamps
        • 2
        :confused:
        thanks, Toppack, but i am still a little bit confused:.First are Polks radio still availlable, they seem to be popular at sub regata. Secondo i already have 3 FM surface radio ,how bad are they compare to AM surface radio and finaly
        what about 27MHz surface radio compared to (75MHz AM .That you sugest) You see i already have 3 FM surface radio and unless they are no good for rc sub would like to use them
        • toppack
          • Nov 2008
          • 1124
          I think Any radio systems in the Megahertz bands will work okay, it's just the Gigahertz bands that are very limited under water. Only slight differences in range of Megahertz bands.
          For the AM versus FM question, I've been told that AM is better for Subs but I have no experience with FM. I've just always used AM for my surface RC ships, so that's what I have.
          When I started using AM there were Not any FM radios. Does that make feel Old? Yep, it sure Does! :)
          Rick L.
          • toppack
            • Nov 2008
            • 1124
            Sorry, I'm not familiar with Polks RC system. I've always used Futaba or Ace equipment. But Ace no longer makes the kits I liked so much. :(
            Rick L.
            • toppack
              • Nov 2008
              • 1124
              I did an Internet search on Polk's system. I found some guys that really liked them but also some that were having a lot of trouble with them.
              They seem to be Overkill for RC ships, since they are complicated, with a lot of trim adjustments, programming and calibrations (for aircraft) not usually needed for ships and boats. I like to keep it simple, since I have No need to 'Impress the Neighbors',with extra knobs, buttons and LCD displays. :)
              Rick L.
                BINGO! Merriman simply loves our WFLY 6 channel radio, its nice and simple and it works well with its own receiver AND with the SOMBRA LABS one. The Polk receiver has caused us some problems with this radio.
                The WFLY uses Futaba crystals in the transmitter, so you can change the frequency quite easily. It comes set on ch 69.
                • toppack
                  • Nov 2008
                  • 1124
                  Mike or David,
                  The W-FLY system is the new PPM-FM or PCM-FM , correct?
                  Do you know which it is?
                  Have you ever used an AM system for your subs?
                  Rick L.
                  • toppack
                    • Nov 2008
                    • 1124
                    I found an interesting website , with Info about PPM versus PCM FM.
                    Most of website is in German but this page has been translated:
                    Rick L.
                    • toppack
                      • Nov 2008
                      • 1124
                      Mike or David,
                      Looks like my questions have been Ignored here also. :rolleyes:
                      Oh well, I guess they can't have all the answers. :D LOL :D
                      Or maybe I just have too many questions, ya reckon?
                      Rick L.
                        I'm not an expert on radio, but I do know where the 'on' switch is. Maybe someone could explain what PPM-FM or PCM-FM means? :confused:
                        • toppack
                          • Nov 2008
                          • 1124
                          Mike, the link I posted explains it pretty well.
                          You need to be an Electronics Engineer to Really understand it, tho.
                          PPM - Pulse Position Modulation
                          PCM - Pulse Code Modulation
                          both are types of, FM - Frequency Modulation
                          The main thing is that PCM is an improvment over the older FM systems. I was just curious which the WFLY used, since everyone seems to be keeping it a Secret, as to what it is. ;)
                          But I mainly wanted to know if anyone has experience with AM system, in a sub, like I'll be using???
                          Rick L.
                            • 13995
                            Altho there are slight differences in the 2, the main thing is that they are both improvments over the original FM systems. I was just curious which the WFLY used, since everyone seems to be keeping it a Secret, as to what it is. ;)
                            Yes ... ****** .... AM works fine punching through the water as long as its on or near the 40-75mHz bands. It's not the modulation mode that matters, it's the carrier frequency!
                            You trying to make e-bay stuff work for you? No one makes AM gear anymore.
                            • toppack
                              • Nov 2008
                              • 1124
                              Thanks,..................******............:D LOL :D
                              I have enough AM equipment to last 3 lifetimes. ;)
                              Some I built myself, but most I've collected over 40 years in the RC hobby.
                              I know AM is not blocked by hills, buidings, etc. like FM is,
                              so I assumed water would not also, but I wanted to ask the experts to make sure, before sinking my boat.
                              The main reason for the big switch from AM to FM, was that the FM components, in development at that time, were Cheaper to make and assemble, not that it is a better system than AM.
                              Profit Rules, but Not always correct.
                              Rick L.
