Cracked subdriver cylinder
    • 898
    Well I wish you luck with the Bondic - as was talked about in the RGC post, I'm sure you tested the UV resin on the your polycarbonate before actually jumping in with both feet. Hopefully if you tried to chip it off the surface with your fingernail, it wont budge. One can easily be fooled by appearances like a cold solder joint.
