Air Bubbles vs Surface Tension
  • vital.spark
    • May 2010
    • 312
    I opened up some of the slats in my Revell 1:72 VIIC deck to aid in submerging but I noticed in trials that air bubbles didn't escape from these small slats being opened. The bubbles seemed to only escape from the large holes under the conning tower and deck gun hole. I'm wondering if anyone out there has done any testing as to the area a hole has to be before air bubbles will break through the surface tension and escape?
    • 13989
    Those very narrow slots (about 1/16" wide) are worthless as vent channels when you dive the boat (well, they work the first time you diver the boat, before the deck gets wet, after that, the deck might as well be air-tight). The surface tension of water on the deck causes the water to bridge these small openings, preventing further venting.
    You can smear an oil bearing grease under the deck, but that's too messy for my tastes.
    Don't even bother to open those slots up.
    • vital.spark
      • May 2010
      • 312
      What would you use as the minimum diameter of vent holes in your Models?
      Myron
        • 2642
        Aim for 1/8" (3mm) minimum, you can also assist that by countersinking the underside of the hole.
          • 13989
          Myron
          1/8", with a dab of Vaseline underneath and around the hole (smart-ass commentary about hair and other additives not invited from the peanut-gallery!).
          On the 1/72 Type-7, you'll find the bollard heads to be about that diameter. Punch those out and you will have adequately venting of the hull.
