A little project I am working on - Piston WTC
    • 3753
    I have been working on a piston WTC and getting close to a test. Working on wiring. The cylinder is 3.5" and the piston is 2.5" with a 6" stroke. The overall length will be about 19" +/--ish
    I will be running NiMh, but in future tube (providing this works at all, I will try other types of batteries.
    • 1647
    And you call this a LITTLE project, don't want to know how much time is used for designing and building this contraption.
    I do have a question, how will you manage the pressure which this type will create?, thinking more at which feedtroughs you can use to contain the pressure within the WTC, i will watch and learn.
      • 2639
      Pressure should only rise by about 2.5-3psi, seals should cope with that without any complaint. Had WTC's with recirculating compressed air run at double that pressure without issue with the seals. I would beef up the gears on the tank though if they're resin. Also consider making them herringbone pattern, which will be stronger and they run quiet.
        • 898
        Nice! How are you doing the limit switching?...micro switches? maybe hall effect devices?
          • 3753
          Manfred, the motor has cup seals facing opposite directions. pushrods are simple o-rings. No guarantees until test time. That being said, it is what others have used so we will see.
          Andy, using resin is also part of the experiment. If resin does not work well, I will cast it in brass and try again.
          Bob, thank you, it is using micro switches for limiting the end travel and hall sensor for proportional travel.
          This is a fun exercise for the brain.
            • 2639
            Others have already got arrows in their backside with this, so no real need to experiment. Look at Ron P's tanks- he uses very deep resin cast gears, and they're helical pattern which gives more strength although does impart an axial load, which is why I suggested a herringbone pattern as they cancel out any axial thrust.
            it's up to you of course, but bear in mind you tend to find a weakness at the most inconvenient time e.g. when at the bottom of a lake.
              • 3753
              Andy, duly noted!
                • 898
                ...And that would be what- answering all the questions being asked or scratch fabricating a ballast system?
                  • 3753
                  LOL.....I did not think that statement through, working on a ballast system. Actually, this hobby as a whole is really great for keeping the noggin working.
