Side by Side Radios
    • 831
    Side by Side Radios
    It would be nice if they made a stand alone telemetry receiver to eliminate the need for the complete 2.4 Gig transmitter/receiver. Then you could run a 2.4 receiver just for the telemetry (and not use the receiver portion) side by side to a 75MHZ command and control ( term credit..Ed) receiver. They are small and cheap enough and would run off the BEC. Only drawback..they would only be operational at periscope depth-not a big deal...you'll probably be there a bunch of times during the run anyway.
    • 12317
    How many Watts does that on-board receiver poop out? Might be too much for some BEC's.
      • 831
      Good point! Correct that-UBEC they can be 10amp+(which really means 7amp in Chinese)
