servo linkage o-ring
  • secrtwpn
    • Feb 2012
    • 182
    Is there any type of lubricant that I can put on the servo linkage where it passes through the o-ring at the aft end of the cylinder? I have worked it through several times. It is loose, but still makes the servo tray flex.
    Farlan
    • 12332
    silicon oil
    • secrtwpn
      • Feb 2012
      • 182
      Brand please
        • 12332
        Originally posted by secrtwpn
        Brand please
        Ease Release™ 200 is an excellent general purpose release agent for making molds and casting parts.
        • Bob Gato
          • 831
          Farlan
          This might look familiar to a lot of people -Maybe you might need a linear linkage on that servo...so it doesn't bind ....Brilliant!! design.
            • 12332
            Yes...... … if your SD has room for it.
            • secrtwpn
              • Feb 2012
              • 182
              Next question. I have have several item s such as a silicone lubricant for the garage door springs. Is there something I SHOULDN'T use?
                • 12332
                Don't use hydrocarbons.
                • secrtwpn
                  • Feb 2012
                  • 182
                  Roger that
