Paging David M.
  • DMTNT
    • Jun 2018
    • 297
    Paging David M.
    When you get a sec, can we touch base on something? Thank you!
    Dead men tell no tales...
    • 13688
    shoot...…………...
      Careful Dude. This is like sumoning the horned one - the outcome might be interesting!
      • DMTNT
        • Jun 2018
        • 297
        shoot...…………...
        Howdy. Your email didn’t change, did it? I wanted to send you something as a thank you.
        I also managed to get into a bind and need to source another Seawolf rotor. Ideally another one of yours if I can. If that isn'’t doable, I wanted to get your take on using a 30mm impeller from a ducted fan motor for an RC plane in its stead.
          • 13688
          Scott: **** you! And finish that NOVEMBER hull -- what's the hold-up???!!!!!
          DMTNT: I'll fix you up, no sweat. I'll send along a pair of rotors. Anything else I should slip into the package? Send me your mailing address.
          • DMTNT
            • Jun 2018
            • 297
            Email inbound. Thank you!
