New SD issue
  • secrtwpn
    • Feb 2012
    • 182
    New SD issue
    I’m working on my 2.5” engine deck. I inserted the control rods for the rudder and aft diving planes thru the o-rings and connected them to the servos. When I test the system, the torque from the servos causes the engine deck to flex and it does not move the control rods. I’ve tried sliding the rods back and forth to loosen up the o-ring, but I’m having no luck. I’m using 1/16” brass rod. Any comments out there?????
    Thank you
    Farlan Clutters
    You have to keep bending the push-rods till there is next to zero flexing. You must use silicon grease on the rods as well. Petroleum based oil will only make them stick.
    Is this for the SD cylinder I just fixed for you? It went out to you last week, by the way.
    • secrtwpn
      • Feb 2012
      • 182
      Yes it is.....ill keep working on it
        Farlan,
        Sometimes the o-ring in those can be tight. If you tried what David said and it is still tight, you have several options. The first is take a new piece of 1/16th in rod and run it in and out and turn it to. This may be sufficient. If not you could lightly steel wool or extremely fine sandpaper your pushrod. This will let it pass smoothly, but done too much and can leak. If you do not want to do that the next two suggestions can compromise the o-ring and you may have to replace,
        You could take the piece of rod and score it with sandpaper. Then place it in the hole with silicone grease. Turning the rod will remove a small mount of rubber. Test and redo as necessary. This final way was recommended by David on my Gato. Take a 1/16 drill bit and run it through. David said the rubber will squish around the bit and knock some of the resin down and reseat the o-ring. He said if it does not work, I knew where I could get another seal.
        Seal replacing is easy to do.
        • secrtwpn
          • Feb 2012
          • 182
          I'll try it! Thx!
          • secrtwpn
            • Feb 2012
            • 182
            Got it working! Thanks for all the help!
              Excellent! Go forth and sin no more.
              • secrtwpn
                • Feb 2012
                • 182
                Dave,
                I'm getting ready to charge the bottle in my SD for the first time. Is there anything I need to know or to do?
                Thx
                Farlan
                  This is a test to see if I can post.
                    Interesting, earlier today, i tried to respond and it said that my posts needed approval.
                    Farlan,
                    you will do a short puff of gas in the on board bottle. Then with a screwdriver release the gas.
                    this will chill your bottle. Now fill it by holding the filler on for 5 - 10 seconds.
                    this will be the heaviest your sub will be. So check trim to make sure all is where it needs to be.
                    as you use your gas your boat will get lighter.
                    When done or the boat is out of the water, vent off the remaining gas. The summer temps can make that gas build up..
                    enjoy!
