Romeo
    Romeo
    Anyone have some reasonable plans of a Romeo or Type 33? Just askin'
  • gantu
    • 387
    Regards Gantu
      Thanks Mate. Much appreciated.
        I think Arkmodel makes a Romeo. Just sayin
          But if I know you.....you'll probably want to make your own
            Correct - both times!
              Thats what I figured MR. HardRocK...... Lookin forward to it.
                I just finished cutting the centre board and sticking the foam to it. Once its dried (tomorrow) I'll get to work in ernest. New technique this time. Learning, learning, learning.
                  Looks so simple when its all on paper!!!
                  • Davidh
                    • Nov 2010
                    • 719
                    Hi Scott,
                    I am looking forward to seeing this one,
                    ill have to try and swing by sometime.
                    David h
                      Hi Mate,
                      Always welcome at my place. Bring the kids - the pool is warm!
                      • bwi 971
                        • Jan 2015
                        • 940
                        pictures show that you have the frames already....will it be 1/96?
                        grtz,
                        Bart
                        "Samuel Smiles"
                          Yep, 1/96 it is. I cut the frames in thin plastic and glued them into the foam. I away from home until early December, but when I get back Ill sand the hull to the shapes of the frames and then glass it.
