German u-boats in living color!!!
ID:	116494Click image for larger version
ID:	116495Click image for larger version
ID:	116492Click image for larger version
ID:	116491Click image for larger version
ID:	116490Click image for larger version
ID:	116489Click image for larger version
ID:	116488 Or should I say "Colorized. Makes them look more real and modern day. Click image for larger version  Name:	90e59b08e610925b8cbf9a70788b9bc1.jpg Views:	1 Size:	95.8 KB ID:	116493
    A Bakers half dozen
ID:	116555Click image for larger version
ID:	116556Click image for larger version
ID:	116557Click image for larger version
ID:	116558Click image for larger version
ID:	116559Click image for larger version
ID:	116560Click image for larger version
ID:	116611Click image for larger version
ID:	116623Click image for larger version
ID:	116624Click image for larger version
ID:	116615Click image for larger version
ID:	116614Click image for larger version
ID:	116612Click image for larger version  Name:	image_32980.jpg Views:	1 Size:	48.2 KB ID:	116616
      Getting bored yet?
      Click image for larger version  Name:	ae2a689f0795d5a494666d129817854b.jpg Views:	2 Size:	113.7 KB ID:	116619
        "Mama dont take my Kodachrome away"
ID:	116665Click image for larger version
Name:	u73 bridge personel.jpg
ID:	116666Click image for larger version
Name:	Marines artillery flak german sailors crew.jpg
ID:	116667Click image for larger version
ID:	116668Click image for larger version
ID:	116669Click image for larger version
        • vital.spark
          • May 2010
          • 307
          Mark, Some great detail shots! for me it was interesting to see the bare pressure hull of the Type 7 under construction! can you enlarge it?
            I used that same picture to detail upper pressure hull under the decks of my type VIIs with PE decks. I have a similar picture of two type IIs in the same yard from the similar POV to do my type IIs.
              Some great pics, Mark. I picked up a couple new books in Chicago, basically for the pictures in the U boat book of WWI boats. The Brit book, is text only, but lots of storys. The British boat guys would like it. When I finish it I will pass it on for anybody interested.
                Sorry vitalspark, its only 500 size. Gets fuzzy immediately
                  "I think I need a bigger box".
ID:	116758Click image for larger version
ID:	116756Click image for larger version
ID:	116755Click image for larger version
ID:	116754Click image for larger version
ID:	116753Click image for larger version
ID:	116752Click image for larger version  Name:	u552.jpg Views:	1 Size:	109.0 KB ID:	116757
                    Xing out the X at the top right Deletes all your pictures. Not what I wanted.
                      Lets try this again. First, I upload the photos from a folder by clicking on the Icon with the paper and paperclip (top right)
                      Then I clicked on each of the three files I uploaded, choosing large, medium and small. Now those pics are embedded in the text here.
                      medium
                      small
                      Click image for larger version  Name:	Spruance-2.jpg Views:	1 Size:	50.1 KB ID:	116770
                      Next to click on the X top right - opposite the boxes 'upload attachment' & 'Upload form URL'
                      I have found that the first photo uploaded, disappears when I delete the small attachment photos.
                      I doubled the permissible size of JPG files, but that hasn't helped when I select LARGE size. It seems that the first file should be a medium, and the rest are ok as large.
                        I havent been using the paperclip icon, just the large "A" Couldnt make the paperclip work a while back.
ID:	116779 The large A isn't the best way. Did you scroll down to see the pics loaded using the paperclip & sheet icon? Click image for larger version
ID:	116780Click image for larger version
ID:	116777 Ok heres a test picture.
                              Wow! I just tried the paperclip. Works great!
