How to Post Photographs on This SIte
    • 2848
    acceptable files!
    png jpe jpg jpeg gif bmp psd
    Maximum file Size 4608 wide 3456 high (pixels)
    Firstly, Click on Create New Topic. This will open a window for you to post into.
    You can use the Advanced Editor (the big A top right) if you like. It has no bearing on the photo editing.
ID:	115583 Click on ATTACHMENTS - (top right -square with paperclip icon)
    Choose all the photos you want from your hard drive. It's easier to have them all in one folder - BUT you do not need to enter them into your post until you actually need them. If you want to add more pics, you can 'UPLOAD ATTACHMENTS' at any time. You can highlight any number of photos to upload. These will appear below your post window as small icons of the photos with this to the right of the photo. Insert: Thumbnail Small Medium Large Fullsize Remove
    From this ATTACHMENT LIST simply click on Insert: Thumbnail Small Medium Large Fullsize Remove whatever size you require. The photo will post to wherever your cursor is positioned.
    Carry on entering your text until you need the next photo, then select it from the ATTACHMENT LIST by choosing the size you require.
    If you want more photos from a different place on your hard drive, just go to ATTACHMENTS again and select them to add to your list, then select the required photos as before.
    In ADVANCED EDITOR you can alter the
    size of your text and the color
    You can even center the text and the photos
    And use tables
ID:	115582 where you can write text against your photo
    And alternate the text and photos to make it look good! Click image for larger version
    Notice how this text is centered!
  • zhuravlik
    • Mar 2011
    • 95
    I get this when I try to post a legitimate jpeg
      • 2848
      Try loading the jpg into a photo edit program and export it as a different file like pnp.
      • zhuravlik
        • Mar 2011
        • 95
        Sorry Kazzer, I can't do this at the moment. I'm not at home and my simple tablet is not able to do this.. But I'm failing to understand why I can't post a 3600×1800 pixel jpeg from my tablet in this forum. Never had those issues on RCG. I'm feeling a bit idiot... :)
          • 2848
          I have no idea, but it's accepting photos from all over, so I suspect it's a problem your end.
