Subtech Albacore Waterproof Gasket.
  • gra
    • 12
    Can any member advise how I can manufacture a new gasket for Albacore water tight cylinder please.
    Thanks Gra
    • 13998
    If I remember right that gasket was made from square section, closed-cell, plastic foam of some type. You'll have to find some length of cord and cut it to the correct size to fit. Rotsa Ruck with that!
    (One reason I dubbed those things, 'sink-o-matic').
      • 3767
      Gra, you said cylinder? Or is it a box?
        Can't you use a very soft o-ring like the ENGEL subs?
        Rubber gasket made of extra soft NBR50
        Grtz,
        Bart
        • gra
          • 12
          Sorry it is a box.
          Thanks for comments.
          Graham
            • 3767
            O.K. I just wanted to make sure. There is also http://www.mcmaster.com/#standard-gaskets/=12hskok
            They also have sheet rubber. I used that to create a gasket for a camera housing I made.
            tom
            • gra
              • 12
              Hi Tom I am in Australia thanks for info I will follow up down here.
              Graham
                Thanks Gra
                Is there anything left of the old one? Perhaps it can still be used. When I had mine ,and had leaks, I coated the gasket with a generous amount of silicone grease. It helped a great deal. I also drilled and installed more hold-down thumb screws around and thru the outside flange. The Subtek setup whetted my appetite for submarines, and then I moved on to the Subdriver setup. MUCH BETTER!
                • gra
                  • 12
                  Hi greenman 407 the gasket is complete just some areas seem to let a small amount of water in.
                  I shall take your comments on board.This was my first sub and I thought I would get it active again.
                  I have since moved on to subdriver type cylinders for my other two subs.
                  Graham
                    OK Graham, sounds like you have been around the block a few times. Nothing wrong with that. "Private Message" me. Ive got some info for you.
