Thor's 1/72 Alfa - Cabal parts 1 thru 7
  • ShadowPeo
    • Jan 2009
    • 14
    I have parts 1-2 if you want them
      • 13979
      Thanks, still trying to piece some of these chapters back together. Much appreciated.
        I might have the whole thing as a word document as I once printed off a shop copy that I passed on to Angus aka Concrete Turtle.
        Would that help?
          • 651
          All we need now is the kit re released :)
            duh, just noticed Kazzer's got most of them.
              can't find my word copy - I am sure Kazzer would love them to make a whole set, I know I would.
              • ShadowPeo
                • Jan 2009
                • 14
                Already sent parts 1&2 to Dave, after his reply. Converted mine to PDF/A for compatibility and to make the file size smaller
                  Thanks mate -
                  Off topic -hope you liked the Regatta -
                  I think that cylinder needs a bit of an overhaul re the pesky problems you had.
                  A separate BEC, leveller and re do the external battery linkages. Haven't yet got all my photos off of Trenchant - but will post here at SD forum.
                  • ShadowPeo
                    • Jan 2009
                    • 14
                    Yeh working on that now, just sent a PM to mike asking about some equipment and to place and order, also got some RFI suppression stuff on the way, Ferrite Beads, 0.1uF Caps and Transorbs for different voltages all being sent over from FutureLec, enough for 75 different motors (25 each at 12v, 20v and 28v) and 275 odd Caps and it only cost 20$ I want to see if that makes any difference as well, well it cannot hurt at least.
                      Ok were a little off topic - I think you'll will find Justin the cheif problem was what I pointed out at the Regatta - the BEC. Re-work that battery hook up to as that was weird.
                      Back on topic - got any progress photos of your Alfa - how about an Alfa build thread?
                      • ShadowPeo
                        • Jan 2009
                        • 14
                        I am thinking I will only post my builds over to my Blog, because of my involvement in several forums I think that is the best way to avoid conflict. as for the Alfa I have not done any recently as I have been working on Valiant, having said that its also because I really cannot be bothered getting the PE gear out to make the vent corrections it needs as Ferric Chloride is to messy for PE, and I have been unable to find a tank suitable for what I want to do for the AP which is meant to be a better process, having said that if I do a double sided etch on the Ferric Chloride that would most likely give me better results but again at this point it is on hold. the Valiant stuff was easy in comparison to the Alfa gear as I have to eat so much of the Alfa brass away I keep getting undercuts, I think greater agitation may serve to help this
                        • ShadowPeo
                          • Jan 2009
                          • 14
                          By the way, did you receive the PDF file Dave??
                            Sorry, I missed this post. Send 'em over.
                              yes please too Justin.
                              • ShadowPeo
                                • Jan 2009
                                • 14
                                #30
                                I take it from that Dave did not recieve them, I am unable to resend it right now due to the laptop dying and I am unable to send emails (read: to lazy to set up old PC) should get it back this week so I will do it then
