KMC Designs Introduces - The ADF2
Angle Driver & Fail-safe - keeps you on the level!
A new Paradigm in Pitch Control Technology.
Makes all others look like an old valve radio!
UNIQUE - User dictates pitch controller operation
You'll never have to install an ADF2 twice because it always works with your installation while providing the highest performance auto-leveling capability available.
UNIQUE - Simplified user interface
Install it wherever you like, upside down, on an angle, anywhere!
Instant Push-button zero-bubble calibration.
Set-up configuration stored on an EEPROM - so you can forget it.
UNIQUE - Angle control function -self configures
Angle control function is usable in any of the 3 axes and self-configures its polarity so you'll never have to mess with "wires to front or wires to back" again. Just install it the way that works best for your boat, then run the ADF2 through it's simple setup routine and you're ready to sail. (The ADF2 can even be installed flat on the back of a bulkhead!) All setup data is stored in an onboard EEPROM so you can set it and forget it.
UNIQUE - Angle control function overrider Works so you always have full pitch authority and can override the angle command no matter what angle you're at. You're at the sticks, you keep control.
UNIQUE - 3 user-settable sensitivity settings You match the ADF2's capabilities to your boat.
UNIQUE - Push-button zero-bubble calibrate There's no need to tweak your installation because you're a fraction of a degree off, install the ADF2 then push the set button and instantly the ADF2 calibrates itself to your boat's zero.
UNIQUE - 3 Axis digital Sensor Provides even greater sensitivity and resolution than that offered by ADF.
UNIQUE - All new 3-stage fail-safe After 3 seconds of signal loss the ADF2 enters a user defined two-step fail-safe command sequence, enabling a "command blow, pause, then command neutral" on signal loss. (Great for gas systems with no gas saver or RCABS setups!) For systems with gas savers both stages 2 and 3 can be programmed to "blow" to mimic the 2-stage Fail-safe offered by the ADF.
It’s so small, you’ll have a job to find it! 1"x5/8"x3/16"
Compatible with 5 & 6 volt receiver bus systems.
If you order now on the web page, you will receive the new version. Web page will be upgraded shortly.
