Conductive Paint
    Conductive Paint
    I am thinking of carrying this material at Caswell Inc
    Does anyone see any potential in the model submarine arena?
    • 3670
    Mike,
    Very creative and interesting.
    It would be a great way to get "wires" to those very tiny LEDs. Any idea of the resistance? Does this one have silver in it? What is the shelf life once open?
    • crazygary
      • Sep 2012
      • 610
      Looks like a definite "game changer"!!
      Stock away, Mike!!
        • 2505
        Pretty lossy going by the datasheet. Low draw applications only.
          http://www.bareconductive.com/file/2...ctricpaint-pdf
          My main purpose for engaging this material was for PCBs and the like. I have started to carry MG Chemicals line of boards, developers and etch materials, so this seemed a natural. MGC also have a number of silver repair solders etc. I honestly can't see too many applications for submarines, but if you don't put the goods on the shelf, they'll rot in the warehouse!
          I am also working on a new kit for photo etching using cupric acid etc. My main difference is the tank, and I 'hope' to have it operating by spraying the etch onto the boards or brass sheets. It should be faster and less problematic that ferric chloride, which is messy to use and a pig to ship.
            Mike,
            Yes it has silver in it. Seems to have an indefinite shelf life, but that would depend on the storage conditions once opened. I think this is water based.
            • crazygary
              • Sep 2012
              • 610
              According to the manufacturers information, this material will handle up to 12 VDC.
              Not too shabby, since most of our modeling applications are less than that!!
              Extremely usefull for very small units, such as "Trouts" Aluminaut!!! Small diameter hull tube
              and in need of numerous internal components. The less internal wire, the more room for essential
              parts!!
              Just sayin'!!
                • 3670
                Gary,
                I played with the cheaper carbon version of the paint for the aluminum and the results were less than spectacular. The resistance was a huge factor in not using it. For small distances it worked, but when I drew out longer lines it just did not work well at all. Then adhesion was another issue. It flaked off so easily that it was frustrating. I found that the pastes/pens with silver were much better, but the professional ones were big dollars (or Pounds) and the shelf life was 6 months or less. Since I would not use it in enough quantities or in that short time frame, I abandoned the idea.
                  • 2505
                  If you want very fine electrical connections, then check out litz wire. This stuff is heavily used in the micro aeroplane field.
                    • 3670
                    Learn something new and I can use this tip! Thank you!
                    • crazygary
                      • Sep 2012
                      • 610
                      Thanks, Tom!!
                      With regard to that conductive paint, it would appear that
                      "all that glitters is not gold"!! Hah!!
                      Now, the Litz wire seems worth checking out! Thanks, Subculture!!
                      • Buellman1
                        • 93
                        If the goal is this flat concealable wire. I'd suggest copper foil tape. Used for stained glass and very successful as the traces for home made slot car tracks. Has an adhesive back, takes solder well and is mere thousandths thick. Widths vary, but I bet you could slice it even narrower if you like.
