specifications for Caswell MBD U class sub
  • roedj
    • 564
    Sirs,
    I believe there's something wrong with the specs you have listed for the U class British sub. Either the specs for the model are correct and the scale is wrong or the scale is correct (1:48) and the dimensions for the model are wrong.
    Thanks for your time,
    Dan
    Assuming John Lambert Plans are correct, and he has the boat at 191 feet. WIkipedia confirms this length.
    I need to check that the model length is correct at 68.5" If so, then you are correct, the scale we have listed is incorrect, I think it should be 33:1.
    We'll see! Thanks
      Scale should read 33:1
