Servo Reverse and Gato Bow Plane Retract
  • vital.spark
    • May 2010
    • 312
    I've built up my Gato subdriver and installed it in the Sub. All functions are working but I'm not getting full movement on the Bow Plane retract and my Rudder stick is backward.
    Does anyone know why my rudder throw won't reverse even though it say's reverse?
    I would like to know from David the actual center to center distance (center of servo shaft to center of servo arm where pushrod aattaches)? I have the pushrod in the 3rd hole but still not getting full retract movement only about 85%.
    Regards to all in the Forum,
    Myron
  • shamrock
    • Jan 2009
    • 69
    i to only get the 85 percent movement . have tryed just about every thing .hope this thread brings some answers
    horse power by the hour
      • 13968
      Most often the problem you both speak of is a result of the retract mechanism being set too high in the bow, Lower it a bit and you'll find that the retract struts will push the bow planes fully out when rotated to the 'deployed' position.
