Caswell SV1 Solenoid
  • subcapt101974
    • Feb 2011
    • 102
    Just received an sv1 6v solenoid valve from Caswell tu use as a vent for the ballast tank in my wtc. The only way this could work is if I installed it outside the wtc however I assume that it must be waterproofed before I do this. I was thinking of plasti dip but the way it is made I think it will damage the solenoid if I plasti dip it. Does anyone have any thoughts on this? This is for a Revell Type 7 with D&E WTC. The original valve leaked all summer and I tried everything to make it stop. It's a small leak but I have to command a blow almost every 5 or 6 minutes of surface running.
    These solenoid valves have a vent on their sides, so Plastidip would block that.
    Have you tried replacing the D&E Valve?
    • subcapt101974
      • Feb 2011
      • 102
      David will be sending me a new vent valve assembly.
