Darnell X Craft Build Update
    • 2848
    I've spent most of the past 8 months remodeling my house and today I found a few moments to remodel my X Craft. The break from the model has been very good as I was stuck and couldn't figure out how to fix the difference in height for the push-rods and how to get at the overall aft assemblies easily.
    It dawned on me eventually that Darnel hadn't designed the top cover very well, as the push-rod and prop shaft connectors were extremely difficult to get at. So, with a fine toothed tenon saw, I removed about 6" back on the upper half as you can see from these photos.
ID:	99858Click image for larger version
ID:	99859Click image for larger version
    I now have to figure out some sort of bulkhead to hold the aft push-rods and prop shaft in place, in order that the Sub-driver locates the Kilk-ons and dogbone correctly.
    Any ideas on how I should do this would be appreciated.
    I'm going to fix the smaller upper section so it is held on with magnets, just like the larger section.
    The boat is almost ready for the water.
  • Slats
    • 1776
    Hey Mike,
    good to see this is back on track. A great boat, that I'd consider getting away from 72nd scale to do. Bigger photos please.
    J
    sigpic
      • 2848
      Originally posted by Slats
      Hey Mike,
      J
      We have been donated a model X Craft from Alan Poole UK. It's a better, and more accurate model than Darnell's (bearing in mind that Darnell's was done with very little reference material being available back then). As soon as David has a spare moment, he's going to make a master from the model. (We have Alan's permission).
      • Slats
        • 1776
        Hi Mike,
        what size and scale is Alan Poole's one?
        J
        sigpic
        • Slats
          • 1776
          Hi Mike,
          J
          Bump'd this Mike.
          Would love to start saving mate for when David circa 2049 does this.
          any further details on size or Est production time?
          J
          sigpic
