Monstrosity! 1/72 Seawolf
  • ManOwaR
    You know what else is scary? If I would have made the wolf from mdf...I picked up the Permit plug the other day to move it (which is made from mdf) and was shocked. I bet the wolf would weigh around 100 pounds if I made it from that stuff!
    Joel
  • Slats
    Very nice Joel, that comparision is kind of scary (to Permit).
    Got the plans a couple of days back, -yes know they have conjecture - but nice for some basics.
    This will cap off my sub fleet.
    Best
    J
  • ManOwaR
    The work on the sail continues...
    Today's work has been on refining the fillet shape along with some body work. Also, the cap has commenced construction. Note that there is a gap around the whole thing when placed on the sail. this is to accomodate the special coating beveling. Care is taken here to ensure that the demarcation line between the sail and fillet is consistent using masking tape as a depth guide when sanding.
ID:	58183Click image for larger version
ID:	58182 Click image for larger version
ID:	58185 Click image for larger version
ID:	58181Click image for larger version
    Check out this comparison between the Permit sail and Seawolf. I can't wait to actually have room to work on the scope rack for this model!
    Joel
  • ManOwaR
    Sail Part 2
    Rocking and rollin’ away on this Seawolf...We’re starting to get a nice pace on her. Not breakneck, but not nothing like before, lol!
    A full day and a half was spent on plug surface preparation getting it ready for intermediate moulding. No detailing has been applied as it’s much easier to polish the plug if you don’t have to worry about wrecking that stuff. The same procedure was used here as was used multiple times on the Permit/Jack project.
    Now because I want to do intermediate mould-work at the same time I am working hard on the sail. Probably one of the more complex shapes on this submarine is the fillet on the front of the sail that serves as streamlining and helps counter the snap roll phenomenon.
    I use the same technique as before with the basic shape:
    I glue the side view part of the plan to a carefully squared up piece of Renshape. I’ll cut the bottom, back and front off carefully using the scroll saw on slow, then hot melt it all back together.
ID:	58099 Click image for larger version
ID:	58098 Click image for larger version
    I then glue the top profile of the fillet on – care was taken to get it perfectly aligned with the side profile location.
ID:	58100 Click image for larger version
    Now I have the basic shape...
ID:	58102 Click image for larger version
    On to enabling myself to fit this part properly. I’ll adhere the top-down profile to some cereal box cardboard, and then the bottom of the side profile to some very thick, rigid cardboard. I love cardboard; it’s cheap and plentiful building material. I liked using it as a kid to make laminated finger skateboards and cardboard half pipes to sell them for exorbitant prices to my friends!
    The sail Is hot melted to the top-down profile, and then this is hot melted to the bottom profile. Remember, the sail will not be perfectly flat against the round hull. Only when it is hollow will it fit right, therefore the bottom will have a kind of funny look to it for now.
ID:	58105 Click image for larger version
    The fit of the fillet was pretty good right off the get-go. Only a little sanding was needed to get the fit right.
ID:	58108 Click image for larger version
    Once fit, I taped off the line that will represent the slight demarcation between the sail and the fillet. Tamiya tape was used here, cut into very thin slices.
ID:	58109 Click image for larger version
ID:	58110Click image for larger version
    Looking at lots of pictures of the fillet shape for reference, I simply used sandpaper to sculpt the rough shape.
ID:	58112 Click image for larger version
ID:	58113 Click image for larger version
    More to come,
    Joel
    YEAH!
    What he just said!!!
    No Justice, no peace!
  • Outrider
    Lots of colorful language here...but nothing to get all worked up about. It's just some putty and it seems, underneath all the scatology, to do exactly what you want it to do. (Which isn't exactly on point for the Seawolf discussion here, now is it?)
    Not sure the Wizard would approve of a double standard for salty talk. I'm sure he got his ear bent a few times before the pink shorts came out, but not too many.
    Today, I had the chance to use some Evercoat EasySand Not for a submarine project, but the staircase stringers in my new (old) house. They had lots of nail holes, and 30 years of dings and scrapes from furniture removals etc. (One day, I'll finish this joint and get a boat going again! Goddamit!)
    I gave them a coat of primer and boy did they look rough. Some of the depressions were only 'bruises' but never the less, under a gloss coat, they would look like a badger's ass. Of course, they were also chunks missing that needed repair.
    I rummaged around in the garage and found, quite by accident, (we know where nothing is in this dump at the moment) found a tube of this goop. I was in a hurry too, so in no mood to hang around waiting for single pack **** to dry.
    A squeeze of the tube produced a gob of material toothpaste like, except that it slumped slowly, rather like milk fed puppy ****. I mixed some peroxide hardener in and went to work with a metal spatula. Boy! Is this stuff good! Creamy, smooth, wet enough to grab any surface and non slumping on vertical surfaces. Of course, I wasn't applying it more than 1/8" thick and feathering it to a razor edge with the blade. I used a wide blade and scraped it on so I got it on almost perfectly. 15 minutes later, I ran over it quickly with a block and sandpaper and it was done.
    It would be very easy to apply this material to a curved surface using a flat plastic applicator and bending it over the curve as you drag it along.
  • ManOwaR
    The Pictures
ID:	57972 Click image for larger version
ID:	57979 Click image for larger version
ID:	57981Click image for larger version
ID:	57974Click image for larger version
ID:	57978Click image for larger version
ID:	57975Click image for larger version
ID:	57980 Click image for larger version
ID:	57977 Click image for larger version
ID:	57973 Click image for larger version
ID:	57983 Click image for larger version
ID:	57982 Click image for larger version
  • ManOwaR
    Alright,
    I got some bona-fide new work done on this model today while I was waiting for primer and filler to dry on the hull plug. I found some more low spots because I’ve been trying a firmer backer for my block sander. I went this way because looking at the plug from certain angles I could still see some nasty imperfections that my initial guide coat didn’t pick up. I figured it was my foam backer and lo and behold, I was right.
    Anyways, I started out on the sail and things are going pretty good with that. I am making the sail in multiple stages. Build the base sail (no fillet, no cap), make a mould of that part, add negative detailing to the mould (anechoic coating bevelling), make a reproduction of the base with a very heavy surface coating for scribing and also make it so it will be hollow. From there, add a cap and then the front fillet. I’ll describe this better when we get to each part.
    Creating the base was started by taking a perfectly square piece of Renshape and CA gluing cut-outs of the sail shape both side and top. The bottom of the sail is not perfectly straight because of its teardrop shape that follows the curing hull. I cut this line using my scroll saw and then temporarily hot melt glued it back into place. I ensured that my table for my disc sander was absolutely square in relation to the sanding disk. I hot melted the side of the Renshape block to my square let cool and went at removing material knowing that what I was doing was square. When the material from one side was removed I moved the square to the other side of the sail. This is pretty much the same thing I did on my Permit...might as well because it works very well.
    Then its filling and priming time
    Joel
    I use the U-pol brand here in the UK. The main filler I use is easylite, which is nice and easy to sand and spread- just the right consistency for modelmaking. I use 3M acryl red, which is a single part air dry putty for touch-up and hairline filling jobs, comes in a big toothpaste type tube.
    For very strong filling jobs, or if I need to fashion a 'point', I use Milliput super fine white. Drys rock hard and tough and has a very long shelf life. My sticks are years old- I only use tiny amounts of milliput, which is just as well as the stuff is £££- and they still kick okay.
  • Slats
    The scale and sheer size of this thing will make an imposing presence. I cannot wait to harangue my home fleet with this beast's 8 tubes. The hull size will afford heaps of flexibility for a suite of goodies inside.
    J
    Good points about the twin pack materials Andy. There are numerous materials around that will do this sort of work, and I'd suggest a trip to your local auto parts store, like NAPA or Halfords. Ask for a cream type material that will fill small depressions, final finishing etc. These special pastes are extemely creamy, like soft butter and they have no solvent in them. There are some creams around that are solvent drying, but you will end up waiting a long time for them to dry out. I thought we had one in our Evercoat range, but as I haven't personally used all of them, I'm not sure.
    Originally posted by Merriman
    Instead of constantly blasting out text and **** to show how big one's **** is (and I'm guilty of this, from time to time), ..........
    After spending decades getting my ass tossed off other bulletin boards, I've finally found a home. And I think most guys here will agree.
    Post away, Joel, John, and the rest of you homeless bums.
    Charming - just charming! He doesn't change folks! Why me, Oh Lor' - why me? Pink Panties for Merriman - again!
    I too appreciate the free-flow of good sound ideas, sparked by a thread topic. Here, unlike other forums, we work to keep the idiots out so the threads don't get turned into useless gab-fests, and fist-fights. Mike and Outrider (Jim) are always at the ready to squash anyone who gets out of line. As a result, this board gets only a few consistent posters -- but posters of exceptional quality; the abilities ... DEMONSTRATED abilities ... of these guys are the best I've seen on the Internet.
    Instead of constantly blasting out text and **** to show how big one's **** is (and I'm guilty of this, from time to time), much of the discussion here actually result in usable knowledge being offered by our posters.
    Sorry, Joel. I'll shut-up now.
  • ManOwaR
    Originally posted by Slats
    Thanks Mike and Andy, very good technical points and I have learnt something from both of you - in short Mike no - did not know that - thanks
    Sorry to derail the topic thread a bit Joel.
    John
    Absolutely no problem at all guys. I really do welcome the tech talk in my builds, I find that lots of good new ideas happen to pop because of it.
    Joel
