dragging rudder control arm
  • shamrock
    • Jan 2009
    • 69
    help performing inspection today on my gato.found rudder slow to respond. pulled rear bulkhead and removed arm from servo found pushrod sticking in bulkhead .rod is still straight and true.i think the seal may be bad .wanted to ask before pulling s/d apart.if it is seal would like info on how to order complete seal kit for s/d
    horse power by the hour
  • pjdog
    • 302
    Shamrock:
    Had the same problem about 6 weeks ago. Just lube the puch rod. I used some grimRacer speed grease but oil will work or polish the rod some. It fixed my Gato. I find that I must oil the rods before play submarine. I guess the pool chemicals cause corrosion.
    try that.
    jack
      • 13954
      Originally posted by pjdog
      Shamrock:
      try that.
      jack
      You guys are not performing you post and pre-mission checks!
      • pjdog
        • 302
        Guilty - I guess that's why I'm always having problems when I go to the pool. I'm a trial and error person. But I'm getting better.
        Jack
          • 13954
          Jack
          I've done almost 25 years of 'trial and error' in this game so you guys don't have too!
            • 2632
            I don't think it's good advice to use just 'oil'. Unless Dave is using silicone or something exotic for his seals, then mineral based oil will rot the rubber, you should stick to a silicone based grease or oil.
              • 13954
              Right you are, Andy.
              Silicon oil.
