Type VII replacement motor
  • pjdog
    • 302
    What size would the replacement motor be for a type VII S/D. I see Caswell has motors but I need to know what one goes in the type VII S/D.
    Jack
    Jack
    6-7.4 volt, 380 can motor.
    Why?
    • pjdog
      • 302
      replace
      I thought I'd replace the motor that sometimes hangs up. It didn't do it today but normally does. Maybe the new drive shaft couplers are helping that problem.
      jack
        jack
        Understood. But you will have a hell of a time pulling the motor extension shaft if you do swap out a motor. Those things are press-fit tight.
        • pjdog
          • 302
          hmmm
          Well in that case maybe I can just give it a bump when it needs it. If it gets worse Maybe I can mail it to you for an overhaul. I think I was running around my friends pool and a motor was hung up for a while. Battery powered stuff doesn't like being hung up. They get ugly. I may have cooked it. Burnt something. It does seem to be getting better the more I run it. Doesn't hang up as often. I'll tough it out for a while.
          It really runs super on one screw.
          Jack
