DELTA IV Russian submarine 1/96
  • bassplayer1
    • Mar 2010
    • 244
    #76
    Moulding again !!! Here we go with the sail
    • bassplayer1
      • Mar 2010
      • 244
      #77
      While still prepping the 209 for moulding and in between wax coats I dag this one out and started some corrections! Also some beautiful 3D props from Bart are on the way.
        • 1647
        #78
        Nice Yannis, is that the same boat i saw in your shop when we where on Korfu?, Bart has made some nice stuff.
        • bassplayer1
          • Mar 2010
          • 244
          #79
          Yes, it's the one you saw Manfred !!!
          • bassplayer1
            • Mar 2010
            • 244
            #80
            Some dry fitting to check things out. Still more corrections to be done.
              #81
              Its always nice to see things coming together
              Grtz,
              bart
              • bassplayer1
                • Mar 2010
                • 244
                #82
                Grtz,
                bart
                Thank you Bart !!! Looking forword for your props to arrive !!!
                • bassplayer1
                  • Mar 2010
                  • 244
                  #83
                  Items finally arrived !!!
                    #84
                    And in one piece (those antenna parts were of a concern)
                    They look great on the sub.
                    Grtz,
                    bart
                    • bassplayer1
                      • Mar 2010
                      • 244
                      #85
                      They arrived in perfect condition !!! Thanks, once again !!!
                        • 3753
                        #86
                        Bart, outstanding!
                        Yannis, that is amazing and the cherry on top will be those scopes. This is a fun build to watch.
                          • 2639
                          #87
                          What's the absolute limit with these resin printers? The XY resolution seems to pan out at around 0.05-.0.1mm (1.25-2.5 thou) resolution, which should be adequate for all but the finest of detail. Most bureaus don't quote below 0.3mm details.
                            #88
                            I print at 0.05mm layers, can go to 0.02mm but that sometimes mess things up, so I stick to 0.05mm all the time. I lknow about the bureaus, they were not able to print my props, the reason is that the post processing is so abrasive.
                            Quote
                            The walls in your model are too thin for the current geometry and cannot withstand our manufacturing process without breaking. During the intense cleaning process, we blast the model with air and glass beads to achieve a powder-free model. While, for processed and premium finishes, we polish the model with thousands of ceramic pellets.
                            Unquote
                            • coryhenry
                              • Jul 2020
                              • 156
                              #89
                              It seems they could just not do the finishing process, if requested, to get them professionally made.
                                • 2639
                                #90
                                I meant the x,y resolution, which is dictated by the LCD screen resolution rather than the z height.
                                I was looking at resin printing for some fittings for a very small tug I made. Most parts have been hand made, just a small number of bits would benefit from 3d printing namely the bollards and the anchor windlass. The scale is very small at around 1/140, so I wondered if the resin printer could resolve detail on gears this size as i know it's well beyond the scope of FDM. The height of windlass is only about 5mm, I think the frames would be easy to render, but not sure the gear teeth would come out, as they'll be tiny.
