Engel Sub power question 6 volts or 7.2 volts
  • g2tiger
    • 80
    Team,
    I’m back at the Engel Gato. I got a new (used) control board from Bob Martin for Engel Gato, and the thing works like a charm. Funny how that older technology just goes with the older model and sort of feels right for a WW 2 sub. Now my question is... Can I use 7.2-volt batteries on the 6-volt electric system the Engel system was designed for? I do know that in some cases some equipment will work with a slightly higher voltage but I do not want to let the magic smoke out of the circuit board. I ask because the recommended battery 6-volt 12 amp hour is big and I am having trouble determining where everything will go with such a huge battery.
    So I got to thinking. First, the 6-volt 12 amp hour battery is big forcing the ballast tanks to be angled to allow the piston rods to move freely. This causes the battery and electronics to be where or positioned how?
    The model is already built, and the ballast tanks are troublesome to get back into the original position. The ballast tank mounting is odd in that there is only one screw that holds the tank in place near the center section of the boat while the other or far end appears to simply rest on the hull with the end cap touching the hull and no way to secure it. So, after thinking a bit I thought that I would like to set the ballast tanks down the center line of the hull and use the side spaces of the model and mount the electrics and batteries along the sides of the hull. This would set the ballast tank rods to run out through the center line of the dry space. The tanks do fit down the center and will only need small spacer mounts or feet to hold them offset from the hull, allowing the gears and motors to work. With that plan the large 6-amp hour battery is not going to fit as the piston rods will hit the battery.
    Can I run the model on a couple of 7.2-volt packs? If not straight 7.2 volts, then perhaps a voltage regulator to drop the voltage down to 6 or 6.5 volts to run the equipment tray and motors. Also, if anyone has completed an alternate set-up for the Engel Gato factory design similar or not to what I am trying to do, a photo or two and some details would be helpful. And yes, I have tried to email Engel but for some reason I don’t get any email replies.
    • 2646
    Wouldn’t expect that small a voltage difference to cause any issues.
      • 1658
      Maybe this is the solution which you are searching for.
      7.2 V seems not that much, but which voltage you have in a charged state?.
      To be save i would use a voltage regulator.
