Tiger neptune submarine having a glitch problem need help
  • deepseadiver
    • 297
    Hi everyone I got this submarine tiger neptune from a friend that bought it brand new but ran into money troubles with his home and i was able to get it at a great price of $300 it's never been used he says. When i saw it i turned it on and everything seem to be in good working order but now i see a problem with my new Neptune tiger submarine it was a gift for my son's 13th birthday and I’m trying to figure out what’s wrong with it. I noticed when i turn it on i will get small glitches the rudder, and the planes, will glitch a little but not much but when i turn on the motor at any speed the ballast pump will glitch a lot and then stop and start up again almost like the motor to the prop is causing some kind of interference with the ballast pump why is it doing this. Please help I’m stuck.
    Does the antenna need to be moved else ware? I was also told there’s a adjustment on the CPU or something like this that controls when the fail safe kicks in and it may be dialed in far to low of voltage level . When i put on the prop motor, the power is being drained below a voltage, level i think causing the Ballast pump, to glitch kicking in the fail safe, to go off and on i need some serious help !
    Jim
    there must be someone that's willing to give me advice as many things i can try please its just sitting on the dinning room table doing nothing
  • deepseadiver
    • 297
    so Mike what's wrong with my sub this problem, what do you think it is.
    I think its a adjustment sensor that lets the ballast not be so sensitive so the fail safe does not go into effect what is this unit called . I need to find it and adjust it a little one way or the other until i stop this fluttering gliching what ever you want to call it. All you Smart people out there that know submarines better then i do help me out please .
    JIm
    • deepseadiver
      • 297
      Hi everyone well i purchased the new battery, and yes the new battery, it came with was no good thanks subculture, and Merriman, and Andy from another forum it was the problem hip hip hurray the boat runs great ! I am building a new conning tower i think it will make the sub look much better i like the whole subs apperance but that clear plastic dome has to go i think it looks cheesy. They could have design something better then that well i will be showing my own personnal improvements.
      Jim
