Albacore continued
    I am bitterly disapointed. After spraying the props with the clear flat, now they look milky white. Apparently, too much flat pigment was put in the can. I wouldnt recommend that stuff to anybody. However I cant see myself spending hours trying to sand down these things. Perhaps paint stripper.............We will see.
    That might be paint 'blushing', consiquence of spray painting in a very humid environment. Was it raining when you applied the epoxy clear over-coat? If so, bake the props at about 120-degrees for a day or two and you might save the situation.
    Im just wondering if the paint stripper would harm the white metal that the props are made of?
    Would acetone work on an epoxy coating? Would certainly work on a cellulose lacquer, tip a bit of aceone into a jam jar and plop them in there for half an hour. Worth a try surely.
    Jim Wakefield, who is in charge of maintaining the Albacore emailed me that the Phase 4 configuration only has two masts. The periscope and a radar mast. He also said that the messenger buoys on phase 4 are painted black to match the hull. Good info.
