Atlantis Rises-and Dives
  • Bob Gato
    • 831
    An upcoming Build:
    (I figured that I would keep the pictures off Bob's server and save him a little on data storage)
  • RanSan
    • May 2020
    • 61
    Here is what I have found so far Bob hope it helps.
    Randy
    • Bob Gato
      • 831
      Ah Yeah, it helps big time, Randy! Any possibility of a little more resolution?
      and OK what's the chance you have a close up of the propulsion thruster?
      • Bob Gato
        • 831
        Randy-do you recall-is the stern thruster steerable ? and is it a standard shrouded 3 blade prop?
        • RanSan
          • May 2020
          • 61
          The stern thrusters (2) are a simple set up, there is a thruster on either side of a post which they pivot around. If I remember correctly they could turn almost 90 degrees. The stern and bow thrusters were the same shrouded 3 blade set up. I'm still looking for my pictures which I put in a safe spot, obviously a very safe spot, the search continues.
            • 12311
            I retire next year and will have some time on my hands. May I contribute to this project?
            • Bob Gato
              • 831
              Lol, David...Always Sir!
              • RanSan
                • May 2020
                • 61
                First my respect to all you scratch builders out there. Your talents are amazing. 3D printing doesn't come close to what you can do.
                Bob,
                You reignited my 25 year love of Atlantis from when I was lucky to be on a the build of Atlantis XIV. I have made a 3D file that I will print, thanks.
                • Bob Gato
                  • 831
                  Nice work Randy-what material are you going to use? and what scale? Is #XIV a twin thruster boat?-any chance for a look at the aft end? Exciting project ...Standing by for updates-BG
                  • RanSan
                    • May 2020
                    • 61
                    I use PLA for most of my work. I'm thinking 1/36 scale which would give me around 21". I have been mistyping, I worked on XII but was at the launch of XIV. As far as I remember/know they all had two thrusters on all the subs. My model has fiberglass fairing on the stern because that was the way it was on the build I was on so you can't see all the angle that some of the pictures have.
                    • Bob Gato
                      • 831
                      I still am searching, but it appears that at least Atlantis X had a single thruster and I am assuming that earlier than the Xs also did...I look this picture over constantly and can't find if a second thruster is hiding in the shadows (it also appears on centerline)-plus most of the brochures show a single thruster. -It would be so much easier with one prop-I was considering using a Graupner schottel drive to simulate the thruster but at 50mm it would be to big for a 1/24 build- so now I'll have to go to plan B... Or maybe plan BG.
                      Click image for larger version  Name:	a4.jpg Views:	0 Size:	80.8 KB ID:	144686
                      • Bob Gato
                        • 831
Name:	Screenshot (317) - Copy.png
                        Yes- I got some screen shots from some lady's scuba video-seems that she was wreck diving and along came Atlantis IX and the two divers spent 20 minutes with the sub "playing" like some happy whale circling around them.
                        The Atlantis IX and X are a class of subs and probably the only two 48 passenger versions with single thrusters and open aft structure (the two exact boats that I am looking for)
                        So I took some screen shots-also it is my only documentation of the exterior light positioning..
Name:	Screenshot (315) - Copy.png
ID:	144711Click image for larger version
Name:	Screenshot (318).png
ID:	144712Click image for larger version
Name:	Screenshot (314) - Copy.png
ID:	144713Click image for larger version
Name:	Screenshot (320) - Copy.png
                        • RanSan
                          • May 2020
                          • 61
                          Nicely done.
                          • Bob Gato
                            • 831
                            How freakin' cool is this!
                            my wifes first deep dive 93 ft to the sand bottom. thanks to the atlantis crew for letting us tie up to there bouy so we could make this dive possible.
                            This video shot with a GoPro by divers as Atlantis IX comes by...some great angle views.
                            • Bob Gato
                              • 831
                              I have a build log on another forum-research is done and I have started to draw plans - Scale -1:24 ... 32.5 inch long.
                              https://www.rcgroups.com/forums/show...ises-and-Dives
