Your Filming Format
    Your Filming Format
    1. with the camera on a tripod or in a set of very steady hands take shots of the assembled model, well lit, on the table as you pan around it with an off-camera narrative of what the subject is, scale, special features, performance, and maintenance issues.
    2. Same set-up as above. Removing the model's upper hull as your off-camera voice describes the inner workings. Turn on the r/c system and operate it, explaining what does what.
    3. Static shot of the assembled submarine as you explain the pre-mission, mission, and post-mission checks unique to that particular r/c model submarine.
    4. Tracking shot as you turn on the readied model, take it off the table, proceed to the pool/lake, put it into the water and get it underway.
    5. Circle in the pool slowly on the surface
    6. Circle the pool slowly under water
    7. Do a figure of eight on surface
    8. Do a figure of eight under water
    9. Do a static dive & surface (if you can)
    10. Do a rapid dive and surface at speed.
    11, Repeat 9 & 10 filming under water.
    • 2511
    Number nine is a bit tricky for a dynamic diver. Although I suppose one could always tie a lead brick to it, that will result in a rapid static dive- I don't see anything about a rapid surface!
      Oh! Lor'! There always a smart bottom, isn't there!
      Duly amended (darned Brits - so particular!)
      • oztruck
        • May 2010
        • 317
        Looks like I go first again, oh well.
        What we have here is a 3 part series. Hope you like them
          • 13673
          Excellent video -- you used Mike's recommended format. I appreciate your use of a tripod for the long shots. And your narrative and overlays were informative and not a distraction.
          Good video work describing an excellent conversion.
          • oztruck
            • May 2010
            • 317
            Thanks, I am not good at that sort of thing, happy that you think it is OK
            Cheers Chris,
            • oztruck
              • May 2010
              • 317
              Looks like I posted in the wrong place again, sorry Mike. I have started its own thread.
