CSS Hunley 1/8
  • Pablo
    • Jul 2010
    • 47
    CSS Hunley 1/8
    First of all, I did some research on internet to get all available information, the most interesting was Michael Crisafulli web site where I got the "real" Hunley drawings which have been done after the wreck salvage & study :
    This is the top page of a section that describes the excavation in detail with commentary and that includes a very detailed 3D reconstruction of the Confederate submarine Hunley. This page was originally located at home.att.net/~JVNautilus/Hunley.html
    CSS Hunley PDF Plan is available at 1/24 scale and has to be printed on 4 letter paper sheets. First job was to make the same drawing at 1/8 scale.
    Then, "real" construction was able to begin. The project was to build a 100% scratch model in metal sheets as close as I can to the real one. Hull will be in Zinc, rudder, diving planes, hatches, schnorkell, rivets and accessories in copper & brass.
    First I had to build a wooden "master" of the model where the hull zinc sheets will be bended, cut and put in place.
ID:	100060Click image for larger version
ID:	100057Click image for larger version
ID:	100058Click image for larger version
    My personnal website : http://www.loubet-modelisme.com
  • Pablo
    • Jul 2010
    • 47
    Then I began to built some small parts of the hull to become more familiar with zinc work.
    On the bow wood master I placed the zinc sheets cut and bent then I welded the parts together :
ID:	58918Click image for larger version
ID:	58919Click image for larger version
ID:	58916Click image for larger version
    Same process for the keell :
ID:	58920Click image for larger version
ID:	58923Click image for larger version
ID:	58922Click image for larger version
    All other parts as stern, hatches, propeller turbine, schnorkel box, etc have been built on the same scheme...
    • Pablo
      • Jul 2010
      • 47
      Lower half hull built on the wood "master" :
ID:	58932Click image for larger version
ID:	58924Click image for larger version
ID:	58925Click image for larger version
ID:	58928Click image for larger version
ID:	58931Click image for larger version
ID:	58930Click image for larger version
ID:	58927Click image for larger version
      • Pablo
        • Jul 2010
        • 47
        Upper half hull
        Upper half hull built as the lower one :
ID:	58936Click image for larger version
ID:	58935Click image for larger version
          • 13998
          Excellent work on that 1/8 HUNLEY.
          Here's my work on a contemporary of that boat, the USS ALLIGATOR:
          Same time structures and assembly techniques simulated, but with different substrates and fabrication techniques.
          • Pablo
            • Jul 2010
            • 47
            Hi Merriman !
            I'm glad you like my work, yours is nice too. I like these old subs which have been imagined and built by a single man, not by these big navy engineer teams...
            Pre WW1 subs are really fascinating, every sub is unique and a real piece of genius...
            • Pablo
              • Jul 2010
              • 47
              The hull is now quite finished...
              Hatches and top, diving planes, rudder, propeller, schnorkel, portholes, spar, torpedo and 3,000 rivets are still to be fitted.
              -Diving planes :
ID:	58948Click image for larger version
ID:	58947Click image for larger version
ID:	58946Click image for larger version
ID:	58943Click image for larger version
ID:	58949Click image for larger version
ID:	58945Click image for larger version
              • Pablo
                • Jul 2010
                • 47
                Rudder & propeller :
ID:	58950Click image for larger version
                Rudder is built according to the real Hunley design.
                Propeller is home made too
                • Pablo
                  • Jul 2010
                  • 47
                  Spar & "Torpedo", motorized schnorkel, hatches, portholes and 3,000 real brass rivets fitted on the hull :
ID:	58953Click image for larger version
ID:	58955Click image for larger version
ID:	58954Click image for larger version
                  • Pablo
                    • Jul 2010
                    • 47
                    Hull detail :
                    • Pablo
                      • Jul 2010
                      • 47
                      Hull details :
                        • 13998
                        Pablo,
                        A truly amazing piece of engineering and fabrication on your part. I see how the internal lap-ribs work to grab much of the solder during plate assembly -- the jig you built to hold the frames (and hence the plates) in correct position is a work of art in itself.
                        This is one of the best built articles I've seen to date -- most informative. Keep it up, please.
                        • Rpmtech1
                          • Dec 2009
                          • 229
                          ^^^ I agree as well. I first saw your build on RCG, and its really refreshing to see the craftsmanship, no less in a "exotic" material for most models. It has a great authentic look to it. Nice job man. And I dont say that often to people.
                          • Pablo
                            • Jul 2010
                            • 47
                            Thank you for your nice comments, I'm really happy you like my model.
                            Next chapter, waterproof hull.
                            The hull is made of epoxy resin and fiberglass spreaded in a half cylinder mold (thickness : 2mm)
                            Hull upper deck is epoxy resin & fiberglass too molded between to glass shelves to have a flat & nice surface (thickness 4 mm)
                            Opening of the hull consists in 2 polycarbonate rectangular trapdoors bolted on the upper deck.
ID:	58974Click image for larger version
ID:	58971Click image for larger version
ID:	58975Click image for larger version
ID:	58973Click image for larger version
ID:	58969Click image for larger version
ID:	58970Click image for larger version
                            • Pablo
                              • Jul 2010
                              • 47
                              Last week-end I participated in a sub regatta in Köln (germany), CSS hunley sailed well, here are 2 pics of her underwater.Click image for larger version
ID:	59006Click image for larger version
                              More pics of the event here :
                              and here :
                              hope you like the pics.
