hi buddy .pump was leaking around seam where the two halves meet.pushed two halves together and wraped with a small piece of electric tape . then used the silicone that david sent me to fix the cracks in my s/d pluged the intake and discharge holes with tooth pick and covered the pump end only with the silicone. the stuff is super clear and flows like water .it did the trick and made the pump nonskid against the walls of the s/d will post a pic or two in album if you need . good luck and have fun with the patrols on your trip
s-rock
s-rock
